Jomanche Posted October 7, 2019 Share Posted October 7, 2019 Need a good used BA-10 or AW 4 that will go right in. The AX-15 SWAP is going to be a little too much as I have to get tis on the road. Thanks!!! Link to comment Share on other sites More sharing options...
Big Dan Posted October 7, 2019 Share Posted October 7, 2019 You may have it listed, however, I'm on tapatalk and can't see it. What's your location? Sent from my Pixel 2 XL using Tapatalk Link to comment Share on other sites More sharing options...
jdog Posted October 7, 2019 Share Posted October 7, 2019 I think he meant to put it in the wanted section Link to comment Share on other sites More sharing options...
89 MJ Posted October 7, 2019 Share Posted October 7, 2019 15 hours ago, Jomanche said: Need a good used BA-10 or AW 4 that will go right in. The AX-15 SWAP is going to be a little too much as I have to get tis on the road. Thanks!!! I have one, but I may not be pulling it for a while. It will be pulled late October at the earliest. Link to comment Share on other sites More sharing options...
Big Dan Posted October 8, 2019 Share Posted October 8, 2019 I've got mine pulled, from when I did the AX-15 swap. Still, several states away, however. Link to comment Share on other sites More sharing options...
CapitalCityPioneer Posted October 29, 2019 Share Posted October 29, 2019 @Vakarian Link to comment Share on other sites More sharing options...
89 MJ Posted October 29, 2019 Share Posted October 29, 2019 Where are you located. Mine will be coming out soon! Link to comment Share on other sites More sharing options...
Big Dan Posted October 29, 2019 Share Posted October 29, 2019 He's in PA Link to comment Share on other sites More sharing options...
89 MJ Posted October 29, 2019 Share Posted October 29, 2019 Ok. I’m in WI. Link to comment Share on other sites More sharing options...
