Wounded_Fighter Posted August 28, 2019 Posted August 28, 2019 Why would "newer" rubber fuel line near the fuel cell be cracking/failing just a few months after installed? I've purchased new hose to replace it but I feel like I'm just putting a bandaid on it.
TexanEliminator Posted August 28, 2019 Posted August 28, 2019 4 hours ago, Wounded_Fighter said: Why would "newer" rubber fuel line near the fuel cell be cracking/failing just a few months after installed? I've purchased new hose to replace it but I feel like I'm just putting a bandaid on it. Did you use fuel line rated for EFI? Most auto parts will sell you fuel line that cannot withstand the pressures of EFI as it is designed for carbureted vehicles.
jdog Posted August 28, 2019 Posted August 28, 2019 Did you use fuel line rated for EFI? Most auto parts will sell you fuel line that cannot withstand the pressures of EFI as it is designed for carbureted vehicles. This exactly. When you get fuel line ask for fuel injection fuel line, stuffs expensive but worth it. If you just ask for fuel line they will usually give the cheaper price to make the customer happy. Stock 1988 swb 4.0 ax15 np 231.
Eagle Posted August 28, 2019 Posted August 28, 2019 Also make certain the line you get is rated for ethanol.
Wounded_Fighter Posted August 28, 2019 Author Posted August 28, 2019 1 hour ago, Eagle said: Also make certain the line you get is rated for ethanol. Why would they sell line not rated for ethonal....? 2 hours ago, jdog said: This exactly. When you get fuel line ask for fuel injection fuel line, stuffs expensive but worth it. If you just ask for fuel line they will usually give the cheaper price to make the customer happy. Yeah I just spent 20$ on 4ft. I see the difference.
Wounded_Fighter Posted September 1, 2019 Author Posted September 1, 2019 So far so good, got rid of some of the fuel scent too! Maybe it was seeping out of the old line a little.
