rubiconron Posted September 17, 2007 Share Posted September 17, 2007 What does it mean when my Trans button on the dash lights up? I know there is a little light that is supposed to come on if I flip the switch up. That doesn't work. BUT sometimes when I'm driving the trans picture lights up. It goes off if I hit the button and won't come back on. Just wondering what that means. Thanks, Ron Link to comment Share on other sites More sharing options...
dfreeman616 Posted September 17, 2007 Share Posted September 17, 2007 the little white one above the switch? that's just a light bulb for when the dash lights are on, so sounds like a bad connection, possibly a short. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted September 17, 2007 Share Posted September 17, 2007 tranny lockup switch I think... Link to comment Share on other sites More sharing options...
Eagle Posted September 17, 2007 Share Posted September 17, 2007 There is no tranny lockup switch. The switch sets the tranny in "Power" or "Comfort" mode. Basically, comfort mode makes the transmission upshift at lower RPMs. Later year XJs and MJs eliminated it and hard-wired the tranny in the "Power" mode. Put it there and leave it, the tranny will thank you. Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 18, 2007 Share Posted September 18, 2007 There is no tranny lockup switch. The switch sets the tranny in "Power" or "Comfort" mode. Basically, comfort mode makes the transmission upshift at lower RPMs. Later year XJs and MJs eliminated it and hard-wired the tranny in the "Power" mode. Put it there and leave it, the tranny will thank you. Hey Eagle, did not realize the POWER/COMFORT switch was hardwired to the POWER config later. My 91 might as well be, has not left the POWER mode for at least 7 years. Better mileage, crisper shifting, better performance. Link to comment Share on other sites More sharing options...
Oizarod115 Posted September 18, 2007 Share Posted September 18, 2007 we leave the xj in comfort mode, shifts smooth as butter, and i've heard comfort saves gas cause it doesn't rev as high :dunno: either way it a xj on 35s... gas mileage has long since been null and void. :roll: but the switch is nice, tap power mode and she kicks it in for up-the-hill action or passing and such Link to comment Share on other sites More sharing options...
SoloCamo Posted September 19, 2007 Share Posted September 19, 2007 IIRC, comfort mode makes the transmission "slip" to generate a smoother feeling shift. I know the previous owner kept it in comfort mode, and I keep it in power mode. My tranny seems to be sloppy in comfort mode, especially at higher speeds. Besides, i'm a bit of a lead foot ;) Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted September 19, 2007 Share Posted September 19, 2007 As stated it's only function is to change the shift points on the AW4. For those interested, here is the wiring diagram. http://www.greatlakesxj.com/tech/TCU4.jpg And here is the AW4 service manual as well. http://www.greatlakesxj.com/tech/AW4_manual.pdf Link to comment Share on other sites More sharing options...
