Comanchejess Posted July 10, 2019 Share Posted July 10, 2019 Has anyone else had an issue with the harmonic balancer not being long enough and cutting into the timing chain cover? Model year 1987. Link to comment Share on other sites More sharing options...
87MJTIM Posted July 10, 2019 Share Posted July 10, 2019 Yep. There is a rubber liner that wears out over time. The outer ring will start to drift apart from the inner ring. It will eventually cut the belt and/or the timing cover. You need to change the harmonic balancer. Link to comment Share on other sites More sharing options...
cruiser54 Posted July 11, 2019 Share Posted July 11, 2019 this^^ Link to comment Share on other sites More sharing options...
Comanchejess Posted July 25, 2019 Author Share Posted July 25, 2019 I ended up replacing the harmonic balancer. That was the issue. Thanks! Link to comment Share on other sites More sharing options...
