OldSch88L Posted July 8, 2019 Posted July 8, 2019 Hey guys, question for those of you who did the 4x4 conversion on their 2.5L 2wd Comanche... Pretty much done, ordered an Azzy's design works t-case linkage since I had none, and it doesn't work. From their pictures, the 4x4 shifter should be ahead of the mode selector lever, but in my case, it's pretty much right over it. I guess because of the 4 banger, the transmission sits too much forward. I'm trying to figure some sort of linkage out, but it's a real head scratcher! Any of you dealt with this before?
Jeep Driver Posted July 8, 2019 Posted July 8, 2019 I went with cable..........so...........IDK. Pics would be helpful.
Pete M Posted July 8, 2019 Posted July 8, 2019 Does Azzy's website differentiate any way between the 2.5 and 4.0? have you reached out to them yet? maybe they sent the wrong part?
dasbulliwagen Posted July 8, 2019 Posted July 8, 2019 I had the same issue. The Azzys linkage would not install. I bought new bushings for the OEM linkage and will be installing that.
