ruralandalone Posted June 20, 2019 Share Posted June 20, 2019 i have an 86 with the 2.5l four. The tranny is a 4 speed manual. Jeepforums indicate that it could be either an Aislin AX4 or a Borg Warner T4. Since they use different fluids, and I want to change it, the difference may be important. One uses 90 wt gear oil , and one uses Dextron II.... Link to comment Share on other sites More sharing options...
Green Mesa XJ Posted June 20, 2019 Share Posted June 20, 2019 i have an 86 with the 2.5l four. The tranny is a 4 speed manual. Jeepforums indicate that it could be either an Aislin AX4 or a Borg Warner T4. Since they use different fluids, and I want to change it, the difference may be important. One uses 90 wt gear oil , and one uses Dextron II.... Should be Aisin for that year Sent from my iPhone using Tapatalk Pro Link to comment Share on other sites More sharing options...
ruralandalone Posted June 20, 2019 Author Share Posted June 20, 2019 After checking every manual I own, and on line, I managed to find a serial number on the bottom, so I think it is the AX4. (it had ATF in it, though, which seems to be the wrong stuff) Link to comment Share on other sites More sharing options...
Jeep Driver Posted June 20, 2019 Share Posted June 20, 2019 The TC would have ATF......the trans would have.........well..........you could use 30W motor oil. Link to comment Share on other sites More sharing options...
Pete M Posted June 22, 2019 Share Posted June 22, 2019 On 6/20/2019 at 10:53 AM, ruralandalone said: i have an 86 with the 2.5l four. The tranny is a 4 speed manual. Jeepforums indicate that it could be either an Aislin AX4 or a Borg Warner T4. Since they use different fluids, and I want to change it, the difference may be important. One uses 90 wt gear oil , and one uses Dextron II.... a picture would help clear it up for sure. Link to comment Share on other sites More sharing options...
Eagle Posted June 22, 2019 Share Posted June 22, 2019 AMC used the T4 and T5 as "alternate standard" transmissions in the 1984 and 1985 Cherokee because they were able to source enough AX-4 and AX-5 transmissions. By 1986 I think the supply line issues had been worked out. I don't think I've ever heard of the T4 and T5 being used in 1986. Link to comment Share on other sites More sharing options...
ruralandalone Posted June 22, 2019 Author Share Posted June 22, 2019 Thanks for all of the responses. IT is the AX4, due to the serial number placement. Link to comment Share on other sites More sharing options...
