Sign in to follow this
Starting a build thread after 3 months of owning my 86 Comanche, had a TJ a few years back and ended up having to let it go. Since I sold it I knew I wanted another Jeep  and now needing a truck I stumbled across this gem in Lancaster PA. Drove it home to Baltimore MD in poring down rain with a decent driveline vibration and dry rotted tires, safe I know. But this is a strong truck or so it seems. Here’s a pic from the craigslist ad:
1986 Jeep Comanche X 4x4 Lwb
2.5 l
AX-5
Np 207
Dana 30 front
Dana 35 rear
3.53 gears
31x10.5r15 BFG Long Trail
Seems mostly stock besides some pocket flairs, d window wheels, snorkel, Jks sway bar disconnects, and a homemade front bumper. The rear leaf seems like it may not be the original, looks beefy to me.
Share this post
Link to post
I’ve done a few things since owning her starting with a H4 relay harness, a new headlight switch, and connector. Glad I did this before it caught fire.Threw some leds in the dash while I was at it.
New U joints in the rear drive shaft, had the exhaust patched and re attached to the trans bracket.
Put a new trans mount in, cross member bolt broke but I’ll fix that at a later date.
80w-90 in the diffs, fresh fluid in the Np 207 and a new output shaft seal, for some reason it was impossible to find until I went online.FCF9D71F-A04A-4B68-9734-1A8BB81FF545.png.091e959f9d858a0a9bd816c405f7463e.png
And a oil change after a sea foam treatment. Gonna pull the trigger on some redline soon:cool:
C4A72521-2B41-400D-B584-B2D9E4B38DFE.jpeg.13cf3003d9d977936a1a08d02b5c360b.jpegE49278CD-9438-434D-B7BC-56F207AF427F.jpeg.e1e64b8cd23024a1f3f87b0db554208b.jpeg23BE385E-0B6D-44AE-A5C4-5DAD83C1F64D.jpeg.d659d46024d5933572fd398cb2ff74b3.jpeg
Share this post
Link to post
I plan on doing as much as the work I can myself as I want to really learn how to wrench on her properly. Here is how she’s sitting currently:
D00F21B6-5B9B-4B31-9648-2342C137DAAF.jpeg.38ef6e3878eced75f259949331fdacab.jpegBDE88A5B-6499-4C06-A511-F3CAE30016C4.jpeg.5303c967ceccf4d99836d2fd306030c7.jpeg5AC266BB-2C21-4905-93F5-11DD38A2AB71.jpeg.a9b2ccb33c0c9ebe0eb7089e9222a520.jpeg1D190BF7-D1D3-4984-B48D-C1A701AD9A35.jpeg.fc57b1f334ea3a106ab0f58c29c5d3c1.jpeg7D90BE24-0ED1-4EDC-A0D5-F9790379DA39.jpeg.a605daa8d668270403e05718b6d67c18.jpeg
Share this post
Link to post
Wanted to throw some TJ pics in here for my own archive if that’s cool? Had a lot of great times and were I originally caught the Jeep bug. Was totally stock when I bought it so I painted angry eyes on it and threw a few other parts on it.
991868ED-B8D7-444E-8250-D820D2B79491.jpeg.77c080adc0d5d37e1b382f222b8977e8.jpeg4236F936-5175-401E-A020-373C8293E35D.jpeg.0e79754b4cf9b4eaa60d664277f13882.jpeg7BFB33DF-D131-499C-A21C-1B7B3CE61084.jpeg.69410b23862365363b55362f1ca399a3.jpeg9D6B2A2C-9EF4-4C3A-8783-177C25ED2976.jpeg.e91543ef8a8f986f2b13a8025160895b.jpegF0CBE0DC-2D8D-474C-96C7-B3D2384B4441.jpeg.e0dc0b2f51554d7d5e068fa693907c21.jpeg3305289C-A6EB-43FE-9278-E8584ECB6E34.jpeg.fde0f869a8713c30c9afc8c60daf6fcd.jpeg
4.0 with a 5 speed and some stock axels. Had a OME 3 inch lift, JKS track bar and sway bar disconnect. 33x12.5’s and some other goodies.
Share this post
Link to post
Picked up some wheels last weekend for $50 so I threw them on the mj. They have maybe 30% tread left but have no dry rot unlike my old tires. Pretty much running these till I can afford some 31’s. Then I’ll have to decide which wheels to go with, I like the 16’s but as you can see with the stock backspacing the flares look pretty bad.
66A6976B-FA4E-4A29-892B-2FCD6BFAABF9.jpeg.78bb6ce6a7bcb73e93592749b96c0769.jpeg916F38FB-C612-4EFF-B2CB-EB5DF7272074.jpeg.f1ceb00e64b1b1acf1d3b0ec503f68dc.jpeg
Old vs “new”
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
