schardein Posted May 16, 2019 Posted May 16, 2019 This is from an 85 XJ, so not really an MJ thing, but I've never seen one like it before, so thought I'd share. I don't know what model of transfer case this is for. Notice the "fine print" in the middle: FULLY ENGAGE 4WD BEFORE LOW.
mjeff87 Posted May 16, 2019 Posted May 16, 2019 That's for an NP228/229 TC. Inside the cab, behind the transmission gearshifter, should also be a 2-position switch (lever operated) with "2WD" and "4WD" markings on it. It's actually a vacuum switch that engages 4WD (mode), and then you select the range (hi or low) with the manual lever sticking out of that ^^^ cover plate. http://www.novak-adapt.com/knowledge/transfer-cases/np2xx-early
schardein Posted May 18, 2019 Author Posted May 18, 2019 On 5/16/2019 at 11:21 AM, mjeff87 said: That's for an NP228/229 TC. Inside the cab, behind the transmission gearshifter, should also be a 2-position switch (lever operated) with "2WD" and "4WD" markings on it. It's actually a vacuum switch that engages 4WD (mode), and then you select the range (hi or low) with the manual lever sticking out of that ^^^ cover plate. http://www.novak-adapt.com/knowledge/transfer-cases/np2xx-early Good info, and thanks for the reply. I think there are very few parts for XJ/MJs that I have not seen, but this was a new one for me. I must have missed seeing the vacuum switch, but iirc the rear half of the center console was broken off and gone.
dasbulliwagen Posted May 20, 2019 Posted May 20, 2019 I have an 86 XJ Waggy parts vehicle that has that and the vac switch. My 86 Grand Waggy had that setup too, but the shifter is in a different spot on those. The vac switch setup was cool until the t case exploded going down the road at 30 MPH.
Minuit Posted May 20, 2019 Posted May 20, 2019 On 5/18/2019 at 8:19 AM, schardein said: Good info, and thanks for the reply. I think there are very few parts for XJ/MJs that I have not seen, but this was a new one for me. I must have missed seeing the vacuum switch, but iirc the rear half of the center console was broken off and gone. I think the switch was where the little "coin tray" is in the newer consoles. That's why I love the very earliest XJs. So much early installment weirdness and strange parts that were only used on a handful of vehicles. Then Chrysler got involved and Jeep started acting like a real car company. Boring!
mjeff87 Posted May 20, 2019 Posted May 20, 2019 yep, that's where the swicth sat. I actually have one of them in my parts pile.....I was planing to use it as a poor man's posi-lok (but vacuum operated) on my old CAD axle but never did rig it up. I ended up just locking the CAD collar in the engaged position. I thought I would have a need for 2LO, but I didn't.
