Spectra Premium CU1193
Quick question, yes or no answer.
I'll be doing an open cooling system conversion on my '89 soon. Mostly out of laziness, I'd rather keep the factory cooling fan setup with the switch in the driver side radiator tank. I'd also rather not swap the thermostat housing if I don't need to.
Does anyone know off the top of their head if this radiator has the port in the driver side tank for the fan switch? It sure looks like it does, but I want to be sure. If not, is there an inexpensive radiator with a fill neck on it that does have this port?
