Parts are parts question
Someone has done a ton of changes to this truck.This explains a lot.My interior is gray,but it has a blue bench seat.The console was cut down too.What looked like the original paint is the same red as my XJ hard to tell with the funky Camo over it now.Different motor in it too.Its starting to sound more like Frankin truck someone saved from a salvage yard.
Ok so in could have been built with the 4.0? I saw that 175 mm in there again too.I'm sure the rear is a 35 probably with a newer,or older cover.Its the first one I've seen with the rubber plug that has to be changed its got a bad leak at the rear.So not cool.L knew it was the ELIMINATOR model I found some of the old decal under some paint.
Wagon I have a question. Can I get you any info off the door plate(different door) on my truck.That would tell us anything about that truck? If it could help anyone on here?Or maybe locate the truck if its here in Oklahoma someone may want it or parts?
175mm is what my MJs both listed as rear axle as well. I'd say it's pretty safe to assume it indicates a d35, whatever it's for now.
It would be interesting to compare the option codes on original build sheets to what pulls up from a dealer search. How many of the option codes from the build sheet are on the vin tag under the hood?
6 hours ago, dasbulliwagen said:
There isnt any info on your door that the VIN wouldnt give you through the mfg like what I gave you.
It will tell him the correct engine type, transmission, trim level, and whether it's 2WD or 4WD.
[Edit} Sorry -- the VIN will tell us that. The door tag will give the paint codes. There should be another tag under the hood that also has the paint codes.
The relay harness doesn't have a specific connector. It goes between the factory headlight harness and the headlights. You unplug both the headlight bulbs, plug them into the relay harness, then plug the relay harness into one of the factory headlight sockets. The result is that the factory headlight wiring remains unchanged and completely functional, but now the power that would've turned on the headlights triggers the relays which turns on the headlights.
I would just leave the "third" headlight socket unplugged. Sure you could clip it off but the plug is insulated and it's less likely to introduce corrosion to somewhere important than a wire that was cut off and taped up or something.
