Lthompson741 Posted February 28, 2019 Posted February 28, 2019 Looking into why my ebrake is inop, I assumed it was because of a broken cable, apparently the P.O. removes the bolts/washers off of the threaded rod.   Anyone know what’s supposed to be there hardware wise?   Is it just a washer and a bit?  For some reason I remember a spring on my XJ but could be wrong.  Bonus points if anyone knows what thread size the threaded rod is.  I’ve tried every bit in my collection but nothing seems to go on smoothly.  thanks
All around mj Posted February 28, 2019 Posted February 28, 2019 Are you talking about the part where the one cable connects to two cables?
Lthompson741 Posted March 1, 2019 Author Posted March 1, 2019 4 hours ago, All around mj said: Are you talking about the part where the one cable connects to two cables? Yes sir! Â Sorry, I guess I should of described it better
AZJeff Posted March 1, 2019 Posted March 1, 2019 That assembly is called the "equalizer" Â The two wheel cables attach to a cross-bar that has a hole for the pedal cable between them. Â Â Into to that hole goes a slightly dished washer, plus a nut and a flat washer, all on the rear side. Â The threaded rod from the pedal cable goes in through the front side. Â I 'think' the rod is SAE/imperial/"English" thread. Â The nut would be self-locking, but two conventional nuts jammed together would work just fine. Â The dished washer can be replaced by a couple of ordinary washers or a short steel spacer. Â Â
1989commanche Posted March 1, 2019 Posted March 1, 2019 Mine has two nuts 🥜 and a washer. Just a jamb nut setup. If I remember it looks like 1/4-20 but it’s probably some flavor of metricÂ
All around mj Posted March 1, 2019 Posted March 1, 2019 Do you have any salvage yards nearby? I bet the hardware wouldn’t cost much, especially if you could pull it yourself. I will have to check to see what condition mine is on the parts cherokee tomorrow and see if it’s any good. The whole underside of it looks like the previous owner parked it in the ocean.Â
mjeff87 Posted March 1, 2019 Posted March 1, 2019 OP, there's a pretty good pic of the equalizer setup in this thread: Â Â Â
