ComancheFan Posted January 7, 2019 Share Posted January 7, 2019 So my directionals radio hazards horn coolant temp sensor don’t work when the Jeep is in the run position. Everything will turn on and work if I turn the key back and forth a couple times and it will be in The run position. Once I crank the Jeep to start it the assesories go out. I took apart the top part of the Colum because it felt like the lock cylinder was binding. After taking it apart it appears everything mechanical in the upper part of the colum is moving as it should. I’m considering putting in a new ignition switch. Any suggestions on what I should look for? Link to comment Share on other sites More sharing options...
sammullins2@gmail.com Posted January 7, 2019 Share Posted January 7, 2019 My ignition switches are adjustable Link to comment Share on other sites More sharing options...
Pete M Posted January 7, 2019 Share Posted January 7, 2019 there should be a couple threads in the link in my sig. can't remember if they are outright r-n-r threads but they should have pics and pointers in them. Link to comment Share on other sites More sharing options...
cruiser54 Posted January 9, 2019 Share Posted January 9, 2019 Link to comment Share on other sites More sharing options...
