i know the 4.0 doesn´t require valve adjustments this is for another engine, i´m looking for advice from seasoned mechanics since i´m not one, i just take things apart and put them back togheter.
i have a tsuru b13 with the e16s, it´s a single overhead camshaft, i had have it for like a year or so, and ever since i got it i has a weird ticking noise i always though it came from the valve train so i finally ventured to open it and see if i could fix it, after taking off the cover turns out pistons 2 and 3 had no gap in the valves so i adjusted them following a youtube tutorial (yes, i did it) weird because i expected them to have a large gap somewhere, after checking all the valves i put the cover back and fire it up, next i´ll try to explain the best i can:
before:
cranking speed was good, sometimes fired up quickly, sometimes it didn´t
power was ok but had to give it some gas to not stall while cold, when hot worked fine
after:
cranking speed is slower, as if the engine was too heavy or the battery is discharged but once it begins turning works fine
i feel a noticeable increase in low end power, no longer stalls at idle and overall it feels more torquey
noise remains... now i suspect the timing belt or tensioner...
i´m more than happy with the power improvement but i don´t like the starter like that, my theory is that by adjusting the clearence in pistons 2 and 3 fixed an unnoticed compression leak but in the same time the starter now has to work harder... or did i @#$%ed up?
please move the topic if it shouldn´t be here...
Did you adjust the valves with the engine at operating temperature? It's been a long time since I tinkered with adjustable valves, but my recollection is that the adjustment should be made at operating temperature.
11 hours ago, A-man930 said:
Yes, you might have fixed a compression leak by opening up to appropriate valve clearance (lash).  This is a Honda, right?
nissan tsuru (sentra in the us)
not exaclty, i had to wait for it to coo downl, otherwise you can touch it, so it wasn´t operating temp neither cold
Just now, dasbulliwagen said:
I have no idea what the OP engines are, but air cooled VW's valve lash was supposed to be done stone cold
i´ll check clearences again, just to make sure...
