I just finished lifting my MJ 3.5 inches  in the front.  The factory bump stops are closed to the new coil spring.  It looks like they may start rubbing when I hit a bump.  Is this normal or is there a way to fix this.  This is my first time doing a lift kit.  Also I have adjustable upper and lower control arms which I lengthen a little bit.  Any help would be appreciated.  Thanks
pics would help. :L:  what is your caster set to?  is the tire centered front to back in the wheel well?
I agree with changing the length of the control arms to put the spring/ bumpstop in the correct position in relation to one another. Keep in mind pinion and caster angles when doing this.
