1991 Jeep Comanche Pioneer long bed 4x4...
Build date 3/91
4.0, AW4, D30 front/D35 rear, NP231
Stock for now. Tilt, cruise, sliding rear window, working AC, Jeep TJ wheels, 166,XXX miles. Still operational and is my daily driver (even though I'm retired). Current location is High Ridge, MO. I do have plans to build it some. Front bumper and winch will be first, 3 - 4.5 lift will be second, then a rear locker.
BuildSheetServlet.pdf
  • 1 year later...
body style:jl62
APAS-Monotone Paint
BGAS-Power Front Disc/Rear Drum Brakes
DGSS-4-Speed Automatic AW4 Transmission
DHAS-Lock-Up Torque Converter
DHNS-Command-Trac Part Time 4WD System
DJHS-230MM Front Axle
DMDS-3.55 Rear Axle Ratio
DRJS-175MM Rear Axle
GACS-Tinted Glass Windows
GBBS-Tinted Windshield Glass
GCBS-Front Door Tinted Glass
GEHS-Fixed Door Vent Glass
JAZS-DO NOT USE - See JP, KA classes
JCAS-85 MPH Primary Speedometer
K3WS-STRIPE/BADGE/MOLDING/COLOR
LBCS-Glove Box Lamp
LMAS-Halogen Headlamps
MB1S-Black Front Bumper
MFFS-Black Grille
MMCS-Rear Door Solid Window Insert
MMGS-Belt Moldings
NAAS-Federal Emissions
NBKS-EVAP Control System
NF5S-23 Gallon Fuel Tank
QW7S-Bright White Clear Coat
SBAS-Power Rack and Pinion Steering
SCES-Alcantara Wrapped Steering Wheel
SFAS-Standard Duty Front Shock Absorbers
SGAS-Standard Duty Rear Shock Absorbers
TBMS-Tire Carrier Winch
XBSS-Pickup Box
YAAS-Build To U.S. Mkt. Specifications
Z5AS-GVW/Payload Rating
1AAS-U.S. Dealer Retail
154S-Zone 54-St Louis
*C1-DESCRIPTION NOT AVAILABLE
-SA-Charcoal
ADA-Light Group
ADH-Heavy Duty Electrical Group
ADLA-Skid Plate Group
ALN-Body Color Bumper Group
ARLA-300 Premium Group
BAFP-130 Amp Alternator
BCDP-500 Amp Maintenance Free Battery
CBAP-Straight Back Bench Seat
CKAP-Carpets - Floor and Cargo Area
DGB-All 4-Speed Automatic Transmissions
DHTP-Elec,Shift-on-the-Fly,P/Time T/Case
ERH-4.0L I6 Power Tech Engine
GFDA-Rear Sliding Window
GNCP-Sun Visors w/Illum Vanity Mirrors
GRZP-Left Remote Mirror
GSZP-Right Remote Control Mirror
GTZA-Manual Remote Mirrors
HAA-Air Conditioning
JHAA-Var Intermittent Windshield Wipers
JJAP-Cigar Lighter
KKSP-STRIPE/BADGE/MOLDING/COLOR
KWSP-STRIPE/BADGE/MOLDING/COLOR
K2BP-STRIPE/BADGE/MOLDING/COLOR
K27P-Do Not Use
LAJP-Headlamps On Warning Chimes
LBBP-Courtesy Lamps
LBDP-Ash Tray Lamp
LBEP-IP LED Ambient Light Pipe
LDAP-Underhood Lamp
LHDP-Headlamp Off Time Delay
MBJP-Black Powder Coated Front Bumper
MDAP-Front License Plate Bracket
MHAP-Black Windshield Moldings
MMKP-Lower Grille Surround-Painted Silver
NHM-Speed Control
PW7-Bright White Clear Coat
RAAC-All Radio Equipped Vehicles
RAFA-AM/FM Cassette Radio
RCDP-4 Speakers
SUA-Tilt Steering Column
TBBA-Full Size Spare Tire
TMWA-265/60R18 BSW A/S All Terrain Tires
TZHP-Michelin Brand Tires
WJN-15 Aluminum Wheels
WLZC-All Aluminum Wheels
YEP-Manuf Statement of Origin
YGEA-5 Additional Gallons of Gas
Z01P-Rear Spring Group I
Z67P-Left Front Spring Group XVI
Z86P-Right Front Spring Group XV
3V3A-Customer Preferred Discount
4HA-Special Scheduling Condition I
  • 7 months later...
