rubiconron Posted August 24, 2007 Posted August 24, 2007 None of my interior light work. Both of the lights in the back of the cab have wires run to them but no bulbs as far as I can tell. How do those things work? Thanks, Ron
FxRacing282 Posted August 24, 2007 Posted August 24, 2007 well if there is no bulbs, where's the light gonna come from? hate to make you sound like a dummy :cry:
rockhardzj Posted August 24, 2007 Posted August 24, 2007 well if there is no bulbs, where's the light gonna come from?Pete, we need more smilies!!! Thats funny! :D
DirtyComanche Posted August 24, 2007 Posted August 24, 2007 They take a funky cylindrical bulb. You should be able to get the P/N for them looked up in any auto parts store. If not, I can track down the P/N for you, it says in the manual.
JeeperjohnfromPA Posted August 25, 2007 Posted August 25, 2007 They work two different ways, you simply toggle the lens, (or light cover) up or down. up should turns them on continuously, and down makes them turn on when the door(s) are opened. The Part Number for the Bulb is C11-7W Hope that helps
rubiconron Posted August 25, 2007 Author Posted August 25, 2007 Thanks for the help guys........well the ones that did help. I've never seen a bulb like that. It was just weird. I'm getting used to the parts stores not being able to look up parts for me though. I tried the light earlier but it was in the middle. I guess I need to toggle it up or down to make it work. I'll be working on that in the morning. Is there a fuse for them? Thanks, Ron
FxRacing282 Posted August 25, 2007 Posted August 25, 2007 yes, there is a fuse for anyhting aletrical on a vehicle. i think its under the steering wheel on the left side of the pedals.
DirtyComanche Posted August 25, 2007 Posted August 25, 2007 There is a fuse, but not specifically for them. It normally ins't the problem, those lights just seem to suck for some reason. Mine worked every now and again.
