this is the slave cylinder we just installed in my 89 4.0. (replacing B/A 10 with AX 15) it has a quick disconnect on it ----- need to get it off, so we can connect the new clutch master to it or convert the clutch master to quick disconnect. Precision 619003 --- trans is in
sorry for the oversized pic --- computer issues also
help please
Pull the "hair pin" at the base of the line right were it goes into the main body.....the line will pop out....there is an o ring....replace the line with your old one and push the clip back in.
that's what I'm thinking, Eagle. I tried to unscrew em, no go -- going out a locating an 11mm line wrench to assist with this demolition.
stand by for further details
