hakukamana Posted August 22, 2018 Share Posted August 22, 2018 If you have the time, take a look at the back of the cluster. I am sure you know that the circuits and guages are all connected by a mylar board. Also check the seating of the connector and the terminals. It is not unusual to see some corrosion, either on the connector or the terminals, also the circuit board has specific grounds on the board, they are usually attached to specific guages with the use of a phillips head screw, maybe something has gotten loose. Just don't over tighten the screws the plastic is probably brittle due to its age. The board is also very delicate, so be careful. Link to comment Share on other sites More sharing options...
ratty Posted August 22, 2018 Author Share Posted August 22, 2018 4 hours ago, hakukamana said: If you have the time, take a look at the back of the cluster. I am sure you know that the circuits and guages are all connected by a mylar board. Also check the seating of the connector and the terminals. It is not unusual to see some corrosion, either on the connector or the terminals, also the circuit board has specific grounds on the board, they are usually attached to specific guages with the use of a phillips head screw, maybe something has gotten loose. Just don't over tighten the screws the plastic is probably brittle due to its age. The board is also very delicate, so be careful. Thanks. I did do a cluster swap a couple of months ago. I’ll have to pull it out again when I have time and look it it. Link to comment Share on other sites More sharing options...
Jeep Driver Posted August 22, 2018 Share Posted August 22, 2018 1 hour ago, ratty said: Thanks. I did do a cluster swap a couple of months ago. I’ll have to pull it out again when I have time and look it it. You neg cable from the battery, where does it go? Link to comment Share on other sites More sharing options...
ratty Posted August 23, 2018 Author Share Posted August 23, 2018 1 hour ago, Jeep Driver said: You neg cable from the battery, where does it go? To the dipstick. Link to comment Share on other sites More sharing options...
cruiser54 Posted August 23, 2018 Share Posted August 23, 2018 22 hours ago, HOrnbrod said: ^^ Very important info. It is important. Otherwise the bill of your cap obstructs the view of the ground point. Link to comment Share on other sites More sharing options...
