lostissues Posted August 23, 2007 Share Posted August 23, 2007 the stearing in my comanche that is. what may be the cause for the extra play in my stearing? i replaced the drag link with a rugged ridge crossover stearing kit but i can still swing the wheel back and forth like a little kid pretending to drive, and yet I'm still going in a straight line. anyone know what may solve this dilema? Thanks, Jonathan Link to comment Share on other sites More sharing options...
Pete M Posted August 23, 2007 Share Posted August 23, 2007 Have someone wiggle the wheel back and forth while you watch underneath. Follow the system down from the steering box and see where the motion stops. Depending on your situation, it might not be a single bad part but a combination of slightly bad parts. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted August 24, 2007 Share Posted August 24, 2007 could also be that your steering column shaft is not bolted down tight to the steering box, or that it's just loose, or even that the steering box is not operating correctly due to bad internals... check everything like Pete said. from the column down Link to comment Share on other sites More sharing options...
mfpdm Posted August 24, 2007 Share Posted August 24, 2007 If you have a tilt column, check to see if the bolts on the knuckle are loose. That is the reason I have my donor xj. The bolts came loose on the PO and he freaked out and drove it into a pole. The wheel still steers it just has a lot of play. Link to comment Share on other sites More sharing options...
FxRacing282 Posted August 24, 2007 Share Posted August 24, 2007 check tie rods too Link to comment Share on other sites More sharing options...
jeepthing07 Posted August 24, 2007 Share Posted August 24, 2007 Jack each tire up and grab top and bottom of the tire wiggle it to see if the ball joints are loose. Link to comment Share on other sites More sharing options...
FxRacing282 Posted August 24, 2007 Share Posted August 24, 2007 smart thinking! Link to comment Share on other sites More sharing options...
