Manche757 Posted August 11, 2018 Share Posted August 11, 2018 There is a piece of metal - horizontal - below doors that I think is called a door sill. Does anyone know if new ones are available? Link to comment Share on other sites More sharing options...
AZJeff Posted August 11, 2018 Share Posted August 11, 2018 The door sill is part of the rocker panel stamping, if I recall. (At least at the factory that is the case.) Do aftermarket replacement rocker panels for an XJ include that part of the stamping? Link to comment Share on other sites More sharing options...
Manche757 Posted August 11, 2018 Author Share Posted August 11, 2018 I am asking about the thin aluminum? plate that covers the edge if the carpet and goes under the door. Not part of the frame Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 11, 2018 Share Posted August 11, 2018 25 minutes ago, Manche757 said: I am asking about the thin aluminum? plate that covers the edge if the carpet and goes under the door. Not part of the frame You mean the plastic scuff plates under the doors like THIS? 4DR XJs used the same front plates as the MJs. They didn't come in metal from the factory. Link to comment Share on other sites More sharing options...
Manche757 Posted August 11, 2018 Author Share Posted August 11, 2018 Duh. Yes. They are plastic on the 89. I am not near the 87. Are those plastic also? Hopefully can buy new ones? Link to comment Share on other sites More sharing options...
Manche757 Posted August 11, 2018 Author Share Posted August 11, 2018 Called scuff plates. Learned something Link to comment Share on other sites More sharing options...
Minuit Posted August 11, 2018 Share Posted August 11, 2018 5 minutes ago, Manche757 said: Duh. Yes. They are plastic on the 89. I am not near the 87. Are those plastic also? Hopefully can buy new ones? Yup. Or any 4dr XJ has two of them. Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 11, 2018 Share Posted August 11, 2018 Click HERE Link to comment Share on other sites More sharing options...
Manche757 Posted August 11, 2018 Author Share Posted August 11, 2018 You guys are good. Hope i am not up to quota. Will ask your expertise for possible need for electrical upgrade shortly. Diff thread Link to comment Share on other sites More sharing options...
