Trans to transfer case gasket
I pulled apart my trans and transfer case so i can rebuild my trans. When i removed the 2 it seemed like there wasn’t a gasket? Maybe a light coat of rtv? So if there a gasket i can buy or just rtv? I read on another forum you don’t even need a gasket
40 minutes ago, Jeep Driver said:
The input/output shaft shares a seal. At least mine does, yours should too.
Correct.  There's dynamic seals on both ends.  The adapter space is not meant to be sealed and has a drain on the bottom of it.
There's some exceptions to this out there in other applications, but every factory trans/tcase combo in a MJ will be like this.
