Pete M Posted May 30, 2018 Posted May 30, 2018 had an idea for my uncle's hypothetical cherokee build of removing the rear windows and building some doors for that space instead. It would be a hunting rig with a big swing-out rear tire carrier and I figured that would make it a pain in the butt to retrieve every little thing. so what about putting in doors like on the sides of some truck toppers? then he could grab smaller things quite easily. side benefit that the glass can't break if it's not there. thoughts? eventually my searches found someone that did it to the back window of a 4door.
MeanLemons Posted May 30, 2018 Posted May 30, 2018 Yeah it’s a great idea. Go for it. (Although I haven’t seen somebody build some for 2-doors). I have seen seen a few variants for 4 doors
DirtyComanche Posted May 31, 2018 Posted May 31, 2018 It's a good idea other than it kills visibility out the back... Backup camera might be a worthwhile mod.
Pete M Posted May 31, 2018 Author Posted May 31, 2018 visibility is a concern. I'll definitely "look" into it before removing the glass. I'll be back in michigan in a few weeks and will run the idea by him. a 2door would give him easier access (he's had some major spine surgury) but a 4door allows access to the back area. (rear seats are gone either way)
Pete M Posted May 31, 2018 Author Posted May 31, 2018 my newest thought was to replace the glass with a sheet of metal and then cut a rectangle hole in it for the door, rather than a weird trapezoid that covers the whole hole. but a lot depends on if I custom make everything or buy some prefabbed door assemblies from something.
mjeff87 Posted May 31, 2018 Posted May 31, 2018 Don't do it.......unibody. The rear glass is integral to the frame. ESPECIALLY on a 2-door. It'll fold like a taco, duh.
DirtyComanche Posted May 31, 2018 Posted May 31, 2018 7 hours ago, mjeff87 said: Don't do it.......unibody. The rear glass is integral to the frame. ESPECIALLY on a 2-door. It'll fold like a taco, duh. Woah, am I on Jeepforum circa 2008 Here?
Pete M Posted May 31, 2018 Author Posted May 31, 2018 um, apparently I could put the spare tire there...
DirtyComanche Posted May 31, 2018 Posted May 31, 2018 ^^^ I thought about that for mine but the 37 won't fit there. Not with the shock towers and other body mods.
DirtyComanche Posted June 1, 2018 Posted June 1, 2018 5 hours ago, mjeff87 said: Just because you can, doesn't mean you should...... Why not? The drive doesn't see out that window, which was a point I skipped over prior. Putting the spare on a swingout across the back blocks visibility, laying it down in the back takes up precious cargo space, standing it up takes up space and blocks visibility, putting it on the roof increases drag and CoG while giving you a back injury every time you need to get it up there... I like functional form, as long as it isn't taken too far. I guess that might just be too far for some people.
