Step on brakes, idle rises..
i had the same problem, it was the booster, the diaphram inside it had split causing an air leak when i steped on the brake pedel, replaced the booster and it was fixed. you might also want to replace the vacum hose also, if it is like mine and has weather cracks it needs replced, hose is cheap compared to not having brakes and rearending someone because the hose gave out.
