KANTANKRUS Posted May 18, 2018 Share Posted May 18, 2018 Bell Housing. For this swap we will need a new bell housing: AX-15 will not bolt to the BA10's bell housing. IS THIS TRUE? And if so, what will I need? Link to comment Share on other sites More sharing options...
87MJTIM Posted May 18, 2018 Share Posted May 18, 2018 That is true Link to comment Share on other sites More sharing options...
Big Dan Posted May 18, 2018 Share Posted May 18, 2018 10 hours ago, RestoringNV said: AX-15 will not bolt to the BA10's bell housing. IS THIS TRUE? And if so, what will I need? An AX-15 bell housing Link to comment Share on other sites More sharing options...
johnj92131 Posted May 18, 2018 Share Posted May 18, 2018 Also consider if you want to use an AX-15 with the internal slave or the external slave. Bell housings are different. Wish I had thought of that before I did my AX-15 conversion for the 86 diesel TDI Comanche conversion. Should have done the external slave. Now I will have to convert to the external slave at some point. Link to comment Share on other sites More sharing options...
87MJTIM Posted May 18, 2018 Share Posted May 18, 2018 I have the bell housing for an internal AX15. I am willing to part with it. Are you east coast? (I am guessing not with NV in your name) Link to comment Share on other sites More sharing options...
DirtyComanche Posted May 18, 2018 Share Posted May 18, 2018 Did you buy a tranny without s bellhousing? Link to comment Share on other sites More sharing options...
87MJTIM Posted May 18, 2018 Share Posted May 18, 2018 2 minutes ago, DirtyComanche said: Did you buy a tranny without s bellhousing? They're quite often sold that way. Link to comment Share on other sites More sharing options...
KANTANKRUS Posted May 19, 2018 Author Share Posted May 19, 2018 NVM, I have an intact bell housing attached to my AX15. Donor vehicle 96 Cherokee. I read that wrong and posted it, before really thinking about it. My apologies! Link to comment Share on other sites More sharing options...
KANTANKRUS Posted May 19, 2018 Author Share Posted May 19, 2018 11 hours ago, 87MJTIM said: I have the bell housing for an internal AX15. I am willing to part with it. Are you east coast? (I am guessing not with NV in your name) Restoring NV means, that my Comanche came from Nevada! Link to comment Share on other sites More sharing options...
DirtyComanche Posted May 19, 2018 Share Posted May 19, 2018 3 hours ago, RestoringNV said: NVM, I have an intact bell housing attached to my AX15. Donor vehicle 96 Cherokee. I read that wrong and posted it, before really thinking about it. My apologies! Nice, external slave. Link to comment Share on other sites More sharing options...
