KANTANKRUS Posted May 13, 2018 Share Posted May 13, 2018 I was informed that I could run, mismatched differentials, as long as the front diff was, for example 3.07 and the rear diff was 3.73 is this true? Link to comment Share on other sites More sharing options...
cruiser54 Posted May 13, 2018 Share Posted May 13, 2018 Not at all. Link to comment Share on other sites More sharing options...
Eagle Posted May 13, 2018 Share Posted May 13, 2018 Definitely not. Too much mismatch. Because not all axles have the same size ring and pinion gears, there are combinations where the front doesn't match the rear perfectly -- at the second decimal place. In the XJ and MJ, for example, you'll actually find a 3.07 axle mated with a 3.08, and a 3.54 mated with a 3.55. Those are close enough to work. But 3.07 with 3.73? Nope! Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 13, 2018 Share Posted May 13, 2018 If you ran different tire sizes front and rear it would work w/o generating much diff-killing heat. For example with a 3.07 front ratio axle w. 27" tires and a 3.73 rear ratio axle w. 33" tires, calculated engine RPM would be 2483 RPM vs. 2469 RPM, a difference of only 14 RPM. I think you could run forever with no problems that close.... Would look funny though unless it was a gasser.. Link to comment Share on other sites More sharing options...
omega_rugal Posted May 13, 2018 Share Posted May 13, 2018 1 hour ago, HOrnbrod said: If you ran different tire sizes front and rear it would work w/o generating much diff-killing heat. For example with a 3.07 front ratio axle w. 27" tires and a 3.73 rear ratio axle w. 33" tires, calculated engine RPM would be 2483 RPM vs. 2469 RPM, a difference of only 14 RPM. I think you could run forever with no problems that close.... what he says... Link to comment Share on other sites More sharing options...
KANTANKRUS Posted May 13, 2018 Author Share Posted May 13, 2018 Not gonna happen. I plan to either convert the front diff to 3.73 or both axles to 4.10, running on 33 inch tires. Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 13, 2018 Share Posted May 13, 2018 3 minutes ago, RestoringNV said: Not gonna happen. I plan to either convert the front diff to 3.73 or both axles to 4.10, running on 33 inch tires. Err, good plan. Link to comment Share on other sites More sharing options...
Eagle Posted May 13, 2018 Share Posted May 13, 2018 Of course, as long as you leave it in 2WD you can run mismatched ratios. Most folks doing that remove the front drive shaft just to ensure that nobody accidentally engages 4WD and grenades a transfer case. Link to comment Share on other sites More sharing options...
