I lost one of the 4 bolts that connect the torque converter to the flywheel. Does anyone know where i can get a replacement? The only ones i find are the flywheel bolts
I don't know the size but you are bolting either a "ring gear" or a "flex plate" a "flywheel" is used in a system that has a clutch.....:comancheB:
