Temperature Gauge in ‘87
4 hours ago, Ωhm said:
Seem like you're running a coolant temperature sender (used for gauge), instead of a coolant temperature switch (used for idiot light).
This. From your opening post, it sounds like you have a temperature idiot light, not a "gauge." The light should be either on or off -- it should never glow dimly.
32 minutes ago, Big Dan said:
replace the switch with a temperature sender
Just the opposite. He has a temperature "sensor." He needs to replace it with a "switch" for use with the idiot light.
#WT387
https://shop.advanceautoparts.com/web/PartSearchCmd?storeId=10151&catalogId=10051&langId=-1&pageId=partTypeList&actionSrc=Form&searchTerm=temperature switch%2Fsender&vehicleIdSearch=8505
12 hours ago, Eagle said:
I think THIS is correct for his 87 with idiot temperature light.
That one should work, too. Dunno why, but I started with Auto Zone and I couldn't come up with anything but aftermarket senders for aftermarket temp gauges. So I jumped over to Advanced Auto.
