WolverineCub Posted April 23, 2018 Share Posted April 23, 2018 I need the Exact Comanche Logo Position on Fender Link to comment Share on other sites More sharing options...
Pete M Posted April 23, 2018 Share Posted April 23, 2018 what year? you should put your truck's specs in your sig Link to comment Share on other sites More sharing options...
WolverineCub Posted April 23, 2018 Author Share Posted April 23, 2018 1988 Link to comment Share on other sites More sharing options...
Old man with MJ Posted April 23, 2018 Share Posted April 23, 2018 I have a 88 Pioneer, the top part of the Comanche emblem on the front fender is in line with the top of the fender flare; the 4X4 emblem is in line with the door handle. Link to comment Share on other sites More sharing options...
fiatslug87 Posted April 23, 2018 Share Posted April 23, 2018 Link to comment Share on other sites More sharing options...
Keyav8r Posted April 23, 2018 Share Posted April 23, 2018 Cut a cardboard template to the above dimensions following the door gap as a guide. You can use it on both sides to make sure they are even (not that anyone will see both sides at once, but you would still know if they were different). That's how I put mine on the truck Link to comment Share on other sites More sharing options...
WolverineCub Posted April 23, 2018 Author Share Posted April 23, 2018 Thanks for the Info Guys Link to comment Share on other sites More sharing options...
WolverineCub Posted April 24, 2018 Author Share Posted April 24, 2018 The position is lower that I thought. Why do people install then so close to the top fold? Why doesn't the Service Manual give the location? It looks like it's in line with the top fender flare in an illustration in the manual? Link to comment Share on other sites More sharing options...
fiatslug87 Posted April 24, 2018 Share Posted April 24, 2018 I have three MJs ('88, '89 & '90) I know for a fact the '90 emblem placement is factory (original owner) and the other two are within a tenth of an inch of that one, so I'm sure the above picture is accurate. If they were in line with the top of the flare they would sit right under the PIONEER stripe. Link to comment Share on other sites More sharing options...
