I was gifted a 4.0L I6 to rebuild and replace the engine in my truck (currently also 4.0L I6) due to it appears the rings are leaking and/or several other issues with the engine.  I would like to know if there is a way to identify the year of a block and head, and how would I know if they are HO and if I'm transitioning to HO what other challenges would there be?
In the interest of not creating a bunch of topics, does anybody have any kind of resource or previous thread to show what all can be pulled from under the hood that isn't necessary?  I'm basically trying to remove anything not absolutely critical.
Depends what you mean by critical. For functionality or emissions? Did your motor come with intake? If so, then Renix has an EGR port and HO doesn’t.
There is a casting number on the head that gives you a “range” of years it fits. Same with the block. Newer than ‘95? Has a month/year cast into it by the back on the driver’s side.
Thanks for the info on aging the head and block!
Critical for functionality, heat and AC - not emissions.
Jeep 4.0 I6 Blocks
Year..........Casting No
1987-90.. 53005535
1991-95.. 53008405
1996-98.. 53020569
1997-??.. 53010341
1999-04.. 53010449
Cylinder Heads
Year.............Casting No
1987-90......2686
1991-95......7120
1996-98......0630
1999-06......0331
3 hours ago, HOrnbrod said:
Jeep 4.0 I6 Blocks
1987-90.. 53005535
1991-95.. 53008405
1996-98.. 53020569
1997-??.. 53010341
1999-04.. 53010449
Cylinder Heads
1987-90......2686
1991-95......7120
1996-98......0630
1999-06......0331
Thanks!  This is very useful!
If it’s 0331, look for a cast stamp that says tupy or it may be cracked.
Posted (edited)
4 hours ago, cruiser54 said:
Here's how to transition from Renix to HO:  http://cruiser54.com/?p=100
I think that is actually instructions on switching from the HO back to a Renix instead of the other way around...I see that you're the author of that link, but I'm not understanding what I'm reading - it definitely seems to be describing transitioning from a HO back to a  Renix?
Edited by Katalyzt13
clarification
No. Not at all. It's all about putting a HO engine into a Renix Jeep.
