kryptronic Posted April 8, 2018 Share Posted April 8, 2018 I was talking to my brother-in-law a while back about his MJ. He's the original owner of a 1990 MJ pioneer. Somebody rear-ended him in 1991 and the dealer provided a Fey bumper (or a damn good match for one) as a replacement. Thought that was interesting. Link to comment Share on other sites More sharing options...
54bobby Posted April 8, 2018 Share Posted April 8, 2018 On 4/6/2018 at 5:46 PM, Eagle said: That Fey universal is probably as close as you're going to get, but IMHO it's not very close. I keep wondering if it might be possible to somehow attach MJ bumper end caps to the Fey bumper. That would make it look a lot better. 54bobby, were you able to use the Fey brackets as they came out of the box, or did they require grinding to eliminate body interference? right out of the box worked A.O.K. no grinding and no interference. one thing i did do was to throw a couple coats of rust preventive on all the inside surfaces for a little longer life Link to comment Share on other sites More sharing options...
PCO6 Posted April 8, 2018 Share Posted April 8, 2018 28 minutes ago, krustyballer16 said: Now you got me thinking! Sent from my SM-G892A using Tapatalk I think it would be fairly straight forward. The first decision would be whether to cut and bend the original XJ bumper to continue the factory stamping into the centre section or whether to abandon it all together. If keeping the stamped cross section making 45* cuts on the top and bottom flat sections would be easy. Using and O/A torch to soften the metal for the 45* bends could be done followed by some hammering and finishing with a flap sander should work. You could cut up an original MJ bumper (hopefully a scrap one!) for the centre section or better still use an old Fey bumper. Building a centre section from scratch wouldn't be that hard either. I think you'd also want a horizontal filler strip (diamond plate?) to bridge the gap from the bumper back to the body (more for looks than function). No doubt the XJ end caps would be a nice touch. I'm not close to that point on my MJ (other priorities for now) but I think it would be a fun and cheap project. Link to comment Share on other sites More sharing options...
krustyballer16 Posted April 8, 2018 Share Posted April 8, 2018 I think it would be fairly straight forward. The first decision would be whether to cut and bend the original XJ bumper to continue the factory stamping into the centre section or whether to abandon it all together. If keeping the stamped cross section making 45* cuts on the top and bottom flat sections would be easy. Using and O/A torch to soften the metal for the 45* bends could be done followed by some hammering and finishing with a flap sander should work. You could cut up an original MJ bumper (hopefully a scrap one!) for the centre section or better still use an old Fey bumper. Building a centre section from scratch wouldn't be that hard either. I think you'd also want a horizontal filler strip (diamond plate?) to bridge the gap from the bumper back to the body (more for looks than function). No doubt the XJ end caps would be a nice touch. I'm not close to that point on my MJ (other priorities for now) but I think it would be a fun and cheap project. It could be done lolSent from my SM-G892A using Tapatalk Link to comment Share on other sites More sharing options...
PCO6 Posted April 8, 2018 Share Posted April 8, 2018 1 minute ago, krustyballer16 said: It could be done lol Sent from my SM-G892A using Tapatalk This is not a laughing matter. We need to get to work on it! Ha Ha. Link to comment Share on other sites More sharing options...
krustyballer16 Posted April 8, 2018 Share Posted April 8, 2018 This is not a laughing matter. We need to get to work on it! Ha Ha. I would be interested in EVENTUALLY doing it but you guys keep me busy with the 10753 other projects on here. HaSent from my SM-G892A using Tapatalk Link to comment Share on other sites More sharing options...
fiatslug87 Posted April 8, 2018 Share Posted April 8, 2018 2 hours ago, krustyballer16 said: ...you guys keep me busy with the 10753 other projects on here. Project 10754 in an MJ version??? Link to comment Share on other sites More sharing options...
krustyballer16 Posted April 8, 2018 Share Posted April 8, 2018 Project 10754 in an MJ version??? Who made that one? Could be modified pretty simply Sent from my SM-G892A using Tapatalk Link to comment Share on other sites More sharing options...
