Do I have 1-ton steering?
I have a similar setup. I do have the 1-ton Chevy Tie Rod Ends (TRE). You could call yours cross over steering. I bought my kit from Rough Stuff. Mine is Over The Knuckles, while yours is under. My XJ is lifted 4.5" +. The rear is more like 5.5. This setup made a difference from the stock setup. I do have the WJ Big brakes also. I do not have the steering stabilizer on, that you do. Mine drives fine with out it.  It did shimmy once in a while, when I first had it done.
