gte636p Posted April 2, 2018 Posted April 2, 2018 I've got things sitting around from finishing my lift / axle swap. Rear axle is from a 4.0 Stick comanche (3.07) and is missing drums right now, but complete in every other regard. Was running when removed. Front axle is the standard 2WD beam. Leaves were a little flat but in okay shape otherwise. I'll meet up to an hour away if need be. Just want to give someone the chance to use the parts before they are scrapped.
Pete M Posted April 2, 2018 Posted April 2, 2018 how north in atlanta? I'm over to the east in loganville and would be happy to take those leafs off you.
Dzimm Posted April 3, 2018 Posted April 3, 2018 If the 2wd axle made it's way to Iowa I would for sure take it off your hands. Unfortunately Atlanta is quite a ways away.
gte636p Posted April 4, 2018 Author Posted April 4, 2018 I'm actually in Smyrna, just easier to say Atlanta.
Pete M Posted April 4, 2018 Posted April 4, 2018 I hear that. you're about an hour away. just need to find a time to get out there. probably tack on a trip to the norcross pull-a-part while I'm at it.
SatiricalHen Posted April 6, 2018 Posted April 6, 2018 I’ll take the axles if I could get out that way anytime soon. I’m up in clemson. Do you happen to have that 2wd transmission?Sent from my iPhone using Tapatalk
gte636p Posted April 9, 2018 Author Posted April 9, 2018 You're first in line for the axles. Just let me know when you can get this way. Unfortunately, the 2WD transmission went with the original motor sometime last year.
Archived
