Fuel pump replacement
Got me an new fuel tank and it come with a kit including pump, filter and some rubber parts.
The tank is the same as the old one a 23,5 gallon and i belive it was original mounted on longbed metric ton trucks here i Sweden
 But the pump will not fit, is there two or more versions of pumps to a -89 4.0L Renix  ?
To the left the old Bosch 9580810019 To the right the new SP1157
  • 7 months later...
  • 2 years later...
Hi ,
Old topic but i got some update here which might be helpful for others :
Meat and Doria 76972 dimensions :
Diameter : 43 mm
Intake diameter : 12 mm
Intake part length : 23 mm
Overall length of metal body with intake  : 135 mm
JEEP: 52017698, JEEP: 8933063591, BOSCH: 9580810019, FISPA: 20493, FISPA: 70493, HOFFER: 7506972, MEAT & DORIA: 76972, SIDAT: 70493
Oem 2,5 liter pump no. 8933 002 251, model no. 5550:
Diameter : 37 mm
Intake diameter : 18-19 mm
Intake part length : 24 mm
metal body with intake : 110 mm
In my case where I would like to install it to 2,5 engine is bigger than original one so modifications are necessary.
Below I'm adding some photos how it looks like.
