Jeep Driver Posted March 15, 2018 Share Posted March 15, 2018 XJ, not MJ. Casually looking, thanks. Shipped to 37843 Link to comment Share on other sites More sharing options...
Jeep Driver Posted March 17, 2018 Author Share Posted March 17, 2018 On 3/15/2018 at 8:44 PM, saveevryjp1998 said: What is the difference between the two, i have 1 for sure and will not use since I'm soon to be rid of all my xjs. I did not realize they are different and I have a pile of pedal assemblies. I figure maybe 97 and up but didnt know otherwise. If you can post a pic and I can verify its yours for cost of shipping. I don't' have a pic of an early assembly and I don't know if the 97 up is different. Pedals are moved to the left of the accelerator pedal on the XJ vs the MJ. Link to comment Share on other sites More sharing options...
krustyballer16 Posted March 17, 2018 Share Posted March 17, 2018 This is what I have in all my Comanches...All are set up for brake and clutch from factory. Acc. Is separate on the right Sent from my SM-G892A using Tapatalk Link to comment Share on other sites More sharing options...
carnuck Posted March 18, 2018 Share Posted March 18, 2018 I think the change came with the different brake booster. I ran into that when I put a ZJ brake booster/Master in my ‘87 MJ. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
krustyballer16 Posted March 18, 2018 Share Posted March 18, 2018 I think the change came with the different brake booster. I ran into that when I put a ZJ brake booster/Master in my ‘87 MJ. Sent from my iPhone using Tapatalk Ya, the pins/studs on the pedal are different I know. Sent from my SM-G892A using Tapatalk Link to comment Share on other sites More sharing options...
krustyballer16 Posted March 18, 2018 Share Posted March 18, 2018 This is in an 88. Sent from my SM-G892A using Tapatalk Link to comment Share on other sites More sharing options...
Jeep Driver Posted March 18, 2018 Author Share Posted March 18, 2018 The pedals on the XJ are moved to the left, they are not in the same position as the MJ. This is what I'm looking to achieve. The pin size can be overcome...........not an issue. Link to comment Share on other sites More sharing options...
HOrnbrod Posted March 19, 2018 Share Posted March 19, 2018 The pedal assemblies and mounting brackets for the 91 and up MJs and XJs are identical. - same part numbers The pedal assemblies and mounting brackets for the 90 MJs and XJs and below are completely different then the 91 and up. Don't know about the spacing between the two. Maybe you just need the 91 and up bracketry and pedals? Just a thought.... Link to comment Share on other sites More sharing options...
krustyballer16 Posted March 19, 2018 Share Posted March 19, 2018 I have the 88 assembly in my 91.... bolts up and everything... might be different but bolt the same. The picture above is in an 88. I took my bracket and pedal from my other 88 and bolted in my 91. My 91 assembly is currently in the 86 i just bought. Bolts right up. Sent from my SM-G892A using Tapatalk Link to comment Share on other sites More sharing options...
Jeep Driver Posted March 19, 2018 Author Share Posted March 19, 2018 Thanks guys. I had a lead on one locally, contacted seller..........bla bla bla....when I get around to it I'll contact you blllalalblalblagblabl ........one of my few CL BS encounters. It was a '98. That's really what I want. Only reason I was a little anxious is that I want to install my new steering column but I need to do the pedal assembly first, not after. I'm patient, one will come around. Link to comment Share on other sites More sharing options...
krustyballer16 Posted March 20, 2018 Share Posted March 20, 2018 I still don't know what we were trying to figure out...Sent from my SM-G892A using Tapatalk Link to comment Share on other sites More sharing options...
Jeep Driver Posted March 20, 2018 Author Share Posted March 20, 2018 17 minutes ago, krustyballer16 said: I still don't know what we were trying to figure out... Sent from my SM-G892A using Tapatalk More room at the accelerator pedal. Clutch and brake moved left AWAY from the accelerator pedal. More room for the fun pedal. Link to comment Share on other sites More sharing options...
krustyballer16 Posted March 20, 2018 Share Posted March 20, 2018 More room at the accelerator pedal. Clutch and brake moved left AWAY from the accelerator pedal. More room for the fun pedal. In what year? Sent from my SM-G892A using Tapatalk Link to comment Share on other sites More sharing options...
Jeep Driver Posted March 20, 2018 Author Share Posted March 20, 2018 Just now, krustyballer16 said: In what year? Sent from my SM-G892A using Tapatalk The year I had was a '94, it was a donor, but I suspect it is the same for all years later than that. Link to comment Share on other sites More sharing options...
