SatiricalHen Posted March 6, 2018 Share Posted March 6, 2018 I saw the write up for the SWB by Jeep Driver, but it says empty post in the first post and the closest other thing I can find is HOrnbrod’s LWB write up. Has anyone diyed a rear sway bar on a SWB and has pictures or details? Trying to make the Comanche handle better on the road since I have my Cherokee to beat offroad. Thanks in advance! Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Limeyjeeper Posted March 7, 2018 Share Posted March 7, 2018 Be careful. I tried the Addco kit made the Comanche downright dangerous. Had way too much rear wheel lift Not well engineered really wouldn't recommend it. It was way too stiff. Had the Addco on the front that works fine. If you go DIY don't get too stiff a bar you don't need rear wheel steering !! Link to comment Share on other sites More sharing options...
SatiricalHen Posted March 7, 2018 Author Share Posted March 7, 2018 Why did it lift rear wheels? Was the rear just stiffer than the front? I feel if both are similar in stiffness it should sit fairly flat. Was this all on road or offroad also?Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Jeep Driver Posted March 7, 2018 Share Posted March 7, 2018 Link to comment Share on other sites More sharing options...
SatiricalHen Posted March 7, 2018 Author Share Posted March 7, 2018 Do you have any info on it? Like what parts and stuff, or if you’d go with a thicker or thinner one? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Jeep Driver Posted March 7, 2018 Share Posted March 7, 2018 If I remember correctly it came off a 2000 Blazer The axle mounts are bolt on I welded nuts to the back of mine and then welded the brackets to the axle tube My original links came from a WJ after I went higher I went to adjustables off a 350 Ford Like anything else just be creative and piece it together My truck will never be a rock crawler I don't care about that much about articulation if your truck is driven primarily on Road off road you'll be fine and yes it does handle better much better Link to comment Share on other sites More sharing options...
HOrnbrod Posted March 7, 2018 Share Posted March 7, 2018 15 hours ago, Limeyjeeper said: Be careful. I tried the Addco kit made the Comanche downright dangerous. Had way too much rear wheel lift Not well engineered really wouldn't recommend it. It was way too stiff. Had the Addco on the front that works fine. If you go DIY don't get too stiff a bar you don't need rear wheel steering !! Good advice. I tried several bars before I found the perfect one. The ADDCO kit for the SWB is terribly designed, and mounts the bar on the upper shock mounts using "L" brackets. It should be mounted solidly on the frame. EDIT: Jeep Driver should restore his pics back to his original thread if possible - it's the one I went by when I did my LWB rear bar. Good design for the SWB.... Link to comment Share on other sites More sharing options...
SatiricalHen Posted March 7, 2018 Author Share Posted March 7, 2018 If I remember correctly it came off a 2000 Blazer The axle mounts are bolt on I welded nuts to the back of mine and then welded the brackets to the axle tube My original links came from a WJ after I went higher I went to adjustables off a 350 Ford Like anything else just be creative and piece it together My truck will never be a rock crawler I don't care about that much about articulation if your truck is driven primarily on Road off road you'll be fine and yes it does handle better much better I actually plan to lower the truck and don’t plan to ever really take it offroad besides a possible gravel or dirt road here or there. Do those links go between the leafs or would they hit? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
