Fuel Rail Disconnect O-Rings Broken
Before re-connecting the fuel line to the fuel rail inlet, I verified the o-rings looked and felt in good condition. After connecting the fuel line and priming the fuel pump, it started to leak. Removing the fuel line revealed two busted o-rings (one missing in this pic). I would suspect that I just need to replace the o-rings, but I wonder if I'm missing something else here... :confused: , because I would guess that if I just replace the o-rings will the same issue happen again.
The service manual mentions some repair kit that comes with a disposable plug that you are supposed to replace whenever you disconnect any of these quick disconnects. Does that apply here? Should I just be able to install two new o-rings, and are these o-rings indeed 3/8"?
Thanks a lot.
Fuel disconnects
Quick disconnect part numbers
The Napa part numbers for just o-rings *is:
Napa 730-5018 3/8 Viton individual o-rings
Napa 730-5017 5/16 Viton individual o-rings
*Remember to re-use your old spacer between the 2 new o-rings!!
Napa CRB 212305 fuel line repair kit 5/16
Dorman 800-750 trans line repair kit 3/8
Mopar repair kits:
83502745 fuel line repair kit 5/16
83504447 fuel line/Trans line repair kit 3/8
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
