rokinn Posted February 25, 2018 Share Posted February 25, 2018 I'm looking for advice and opinions on this Ring & Pinion and LSD carrier for my MJ Dana 44 rear axle. https://www.ebay.com/itm/Torque-Sensing-Dana-44-Limited-Slip-Differential-30-Spline-373-3-73-Gears/122839102736?hash=item1c99c7f510:g:CDgAAOSwkLhaIcrJ&vxp=mtr The axle currently has a 3.07 in it with a shot Trac-lock. I was going to go with 3.55 gears but 3.73 would be acceptable, especially at the price for this setup, assuming this is a fit for the MJ Dana 44. The truck currently has a D35 in it and I'm also going to go for new GS military wrap MT springs. Hoping this will allow me to keep the same drive shaft. Thanks in advance for any input. Link to comment Share on other sites More sharing options...
rokinn Posted February 25, 2018 Author Share Posted February 25, 2018 I'm assuming this helical system is similar to the Truetrac??? Link to comment Share on other sites More sharing options...
DirtyComanche Posted February 25, 2018 Share Posted February 25, 2018 I'm very suspicious of what those gears and helical limited slip are and where they came from. That seller has some other odd products. Link to comment Share on other sites More sharing options...
Eagle Posted February 25, 2018 Share Posted February 25, 2018 It says "removed from a brand new rear end." What factory Dana 44 -- from any vehicle manufacturer -- ever came with a true torque-sensing differential? The claim that it's "completely setup" and that the pattern is verified is BS. The pattern will change when installed into a different housing -- the lateral shims will have to be set, and the pinion depth will have to be set. It will NOT be a drop-in. (Unless you're exceptionally lucky.) I wouldn't buy it. Just buy a TrueTrac. By the way, the Dana 44 is an inch longer than the Dana 35, so if you switch from a 35 to a 44 you can't use the same driveshaft. It has to be shortened. Link to comment Share on other sites More sharing options...
rokinn Posted February 25, 2018 Author Share Posted February 25, 2018 Thanks, you've validated my concerns about it also. Too bad. Link to comment Share on other sites More sharing options...
ComancheKid45 Posted February 25, 2018 Share Posted February 25, 2018 2 hours ago, Eagle said: By the way, the Dana 44 is an inch longer than the Dana 35, so if you switch from a 35 to a 44 you can't use the same driveshaft. It has to be shortened. Unless you're running 3" or so of lift, then the stock d35 shaft can be used. (Atleast worked for me with no issues now going on 7 years) Link to comment Share on other sites More sharing options...
rokinn Posted February 26, 2018 Author Share Posted February 26, 2018 5 hours ago, ComancheKid45 said: Unless you're running 3" or so of lift, then the stock d35 shaft can be used. (Atleast worked for me with no issues now going on 7 years) Thanks, good to know. I was thinking that the bit of lift (as has been mentioned on CC before) I got from the new springs would compensate for the added length of the D44. Link to comment Share on other sites More sharing options...
