Jkellahan92 Posted December 4, 2017 Share Posted December 4, 2017 If I lift the front 2 inches will that clear me enough to run wheels with 4 inch backspacing with 30inch tires. Or will I have to lift the rear Link to comment Share on other sites More sharing options...
Jkellahan92 Posted December 4, 2017 Author Share Posted December 4, 2017 I’m thinking that should be enough to clear the fenders Link to comment Share on other sites More sharing options...
yxmj Posted December 4, 2017 Share Posted December 4, 2017 It would be impossible to answer that question without more info.... What is the measurement from center of axle to edge of flair now......front and back Link to comment Share on other sites More sharing options...
Pete M Posted December 4, 2017 Share Posted December 4, 2017 15x7 rims? I'd think with 30s you'd be ok. but the backspacing can really screw with trying to figure things out. Link to comment Share on other sites More sharing options...
DesertRat1991 Posted December 4, 2017 Share Posted December 4, 2017 Telling us the backspacing doesn't help without knowing the wheel offset and width, and the tire width. Stock XJ wheels are typically backspaced at 5.25" - 5.5". Reducing backspacing to 4" would (in theory) increase clearance between wheel and suspension but doesn't tell us how much further inboard/outboard the aftermarket wheel would be compared to a stock wheel. Link to comment Share on other sites More sharing options...
Jkellahan92 Posted December 4, 2017 Author Share Posted December 4, 2017 I’m planning on getting 15x8 pro comps with 30x9.5 Link to comment Share on other sites More sharing options...
