87MJTIM Posted November 29, 2017 Share Posted November 29, 2017 You may have fixed your problem. If you have not already done so, go through Cruiser's Renix tips. Link to comment Share on other sites More sharing options...
Ωhm Posted November 29, 2017 Share Posted November 29, 2017 IAT would have been low on my list of things to check. Good find. Did it take care of your problem? What's Short term/Long term fuel trim values? May take a little time to stabilize these readings. As 87mjtim mentioned, do your cruiser's tips. Link to comment Share on other sites More sharing options...
cruiser54 Posted November 30, 2017 Share Posted November 30, 2017 7 hours ago, 88jeep1 said: So I read somewhere about cleaning the I AT on the intake. I cleaned it and all of a sudden my lean/ open loop went to displaying closed and now lean/rich changing back and forth. I believe I have uncovered alittle of my problem. It went to closed loop almost immediately after cleaning the iat. You should be able to read those values on the REM. Link to comment Share on other sites More sharing options...
88jeep1 Posted November 30, 2017 Author Share Posted November 30, 2017 5 hours ago, cruiser54 said: You should be able to read those values on the REM. Yes what I said in the previous msg was just what I seen the rem was reading. It was just after I cleaned it I seen it go into closed loop setup. It was staying on open before. I'm gonna do some more chk stuff tomorrow. I have done alot of things prior just need to look at the tips to check out other areas. Link to comment Share on other sites More sharing options...
cruiser54 Posted November 30, 2017 Share Posted November 30, 2017 Many times completing the first tips solves issues. Link to comment Share on other sites More sharing options...
88jeep1 Posted December 2, 2017 Author Share Posted December 2, 2017 On 11/29/2017 at 7:06 PM, cruiser54 said: You should be able to read those values on the REM. Could this be one of the idle problems?? Looks caked up? This engine did sit 2 years in its donor truck before I pulled it. The IAT had stuff on it as well. I cleaned it too. Link to comment Share on other sites More sharing options...
cruiser54 Posted December 2, 2017 Share Posted December 2, 2017 Could be. Can you blow through it? Link to comment Share on other sites More sharing options...
88jeep1 Posted December 2, 2017 Author Share Posted December 2, 2017 13 minutes ago, cruiser54 said: Could be. Can you blow through it? Nope Link to comment Share on other sites More sharing options...
cruiser54 Posted December 2, 2017 Share Posted December 2, 2017 should be okay then. Are your lips black now? Link to comment Share on other sites More sharing options...
88jeep1 Posted December 2, 2017 Author Share Posted December 2, 2017 2 minutes ago, cruiser54 said: should be okay then. Are your lips black now? Nope I used a clean vacuum hose. Haha funny guy. Link to comment Share on other sites More sharing options...
cruiser54 Posted December 2, 2017 Share Posted December 2, 2017 4 minutes ago, 88jeep1 said: Nope I used a clean vacuum hose. Haha funny guy. I meant through the valve itself. As if it could be hanging open. Link to comment Share on other sites More sharing options...
88jeep1 Posted December 2, 2017 Author Share Posted December 2, 2017 2 hours ago, cruiser54 said: I meant through the valve itself. As if it could be hanging open. Oh well I didn't get anything to bleed out. I thought maybe they get carbon buildup and just don't function anymore? It seems from reading alittle here an there. The map, egr, and iat heck probably all of them play a vital role in idling. I just thought since the iat was so cruddy looking and the egr had crap on it I may be able to nip this in the butt with those being cleaner. I've gone over alit of grounds. Made the ground area clean used bigger wire. Made multiple ground spots. I think I'm close it's just something little holding it back. Crappy 02 maybe? Link to comment Share on other sites More sharing options...
cruiser54 Posted December 2, 2017 Share Posted December 2, 2017 If it doesn't pass air, that's good. You don't want it hanging open at the wrong time. How fast does your O2 sensor switch rich lean, rich lean? Link to comment Share on other sites More sharing options...
88jeep1 Posted December 3, 2017 Author Share Posted December 3, 2017 1 hour ago, cruiser54 said: If it doesn't pass air, that's good. You don't want it hanging open at the wrong time. How fast does your O2 sensor switch rich lean, rich lean? Quite quickly. I mean I've been running it here an there throughout today. It's warmed up right now I would think thats normal at idle unless I'm wrong on that? Link to comment Share on other sites More sharing options...
cruiser54 Posted December 3, 2017 Share Posted December 3, 2017 Pretty fast is great!!! Link to comment Share on other sites More sharing options...
88jeep1 Posted December 3, 2017 Author Share Posted December 3, 2017 44 minutes ago, cruiser54 said: Pretty fast is great!!! Well that's good to hear. I just bought some if that ox gard stuff tonight going to put that on some ground spots to sure them up alittle better. Still on the hunt for the fix. Link to comment Share on other sites More sharing options...
cruiser54 Posted December 3, 2017 Share Posted December 3, 2017 We'll figure this out. No worries. Link to comment Share on other sites More sharing options...
88jeep1 Posted December 3, 2017 Author Share Posted December 3, 2017 2 hours ago, cruiser54 said: We'll figure this out. No worries. Yes I'm sure it will come around sooner or later the problem. I can't drive it on the road till close the end of December anyways. I mixed the title up with it and the the donor. Now I have to wait to get the good driver one back. Anyways I just got the "big three" I think they call it done. Now its 1 gauge battery wires and ground wires with ox gard on them now. Link to comment Share on other sites More sharing options...
88jeep1 Posted December 24, 2017 Author Share Posted December 24, 2017 Sorry been busy working and stuff for the holidays. Still haven't nailed it down yet. Did come across this issue today. This was initial startup.REM: Open LP , 4.86vO2, Lean EX. After 5 mins running it was: open LP, 0.66vO2, Lean EX. Link to comment Share on other sites More sharing options...
