bhorocks Posted August 1, 2007 Posted August 1, 2007 ok, got the 33's on the mj. still need 2 inches up front to remove the rake. still looking for the transmission and tcase to get the 4x4 goin. been fun thanks everyone for getting me stoked to do this. now the expensive stuff starts.. before lift after lift after 33's
LEAD_NOT_FOLLOW Posted August 1, 2007 Posted August 1, 2007 Looks good! What size coils do you have in the front currently?
bhorocks Posted August 1, 2007 Author Posted August 1, 2007 f150 coils. it actually does not ride to shabby. they will be going away next month when i order some new 6.5" coils. I have a pretty good rake up front i want to get rid of so for now i have some spacers i'll put in. i was looking at the coils from the mercury cougar but they didn't look like the right diameter so i passed on them. Like i said i am still hunting the trans/tcase down and hope to come across one shortly. I am also suprised the 2.5 pushes those 33's pretty well.
Dirtboy075 Posted August 2, 2007 Posted August 2, 2007 Hey did you get that Comanche from craigslist? I was gonna buy one that color, those rims...well it was pretty much that exact Jeep. Just wondering though.
bhorocks Posted August 2, 2007 Author Posted August 2, 2007 i bought it for 500 on craigslist about two months ago. I know there is another 4cyl 2wd on craigslist in phoenix right now as well.
MJ20 Posted August 3, 2007 Posted August 3, 2007 I think I was looking at that mj too, but found a ’89 4wd model here for $800 a couple months ago. I never went up to look at it. Good find. I got mine off craigslist tucson, was searching all the southwest links for a year. I saw your thread on a local board about it. I’ll come up to a m&g or something and check it out. Or if you get it wheeling I’ll be around in my J20 until I get mine going on the rocks.
DansGreyMj Posted August 3, 2007 Posted August 3, 2007 whats the hub to flare measurement with those coils
bhorocks Posted August 3, 2007 Author Posted August 3, 2007 measured 21-22 inches. I am going to put put some coil spacers to level it ous so should come out at 24 after that.
bhorocks Posted August 4, 2007 Author Posted August 4, 2007 ok, could not be helped. everyone has green i know but it just looks so good! I had to do it...
bhorocks Posted August 4, 2007 Author Posted August 4, 2007 mj20 yeah, when we get our junk going i know there are a few mjs around the valley on this board. we should go wheel
offroader461 Posted August 4, 2007 Posted August 4, 2007 count me in for a M&G....nice truck...i gotta get off my @$$ and do my SOA with my longarms :D :D
bhorocks Posted August 5, 2007 Author Posted August 5, 2007 man i want to get the longarms going to. what is everyone runing? I want a bolt on application though
LEAD_NOT_FOLLOW Posted August 5, 2007 Posted August 5, 2007 ok, could not be helped. everyone has green i know but it just looks so good! I had to do it... That looks really good. You rattle can it on? What brand and color did you use?
bhorocks Posted August 5, 2007 Author Posted August 5, 2007 i used rustoleum army green and the hood and bottom ins rustoleum flat black. 30 dollars can't beat that.
bhorocks Posted January 14, 2008 Author Posted January 14, 2008 finally got around to doing some more work.. orioginal lift had ford f150 springs whcih worked well but didn't last long. got some 3inchish re springs put em on. after a few months time to start on the 4wd swap. Should have taken lots of pictures but i didn't. got a great deal on some 4.5 springs and bought 1 3/4 spacer to level out my rake i had so needed to get my caster back to spec. started with adjustable upper control arms and some fixed lowers. still couldn't get the caster right at 6 inches of lift the ride sucked and the death wobble was rediculous. talked to lots of people and almost went with the 3link Rockkrawler kit but after much decisiveness went with drop brackets. after one day of having them its nice... next step tomorrow night i am pulling the 2wd trans out and putting a ax5 4wd behind it. have to change the bellhousing as the v6 doesn't have the CPS slot. no biggie. i'll try to get more pics from here on out to help document and show people some stuff. especailly during the trans swap. still have a lot of cleaning t odo on the trans. it had 1/2 of dirt packed in some places shifts fine though and appears in good running order after the trans swap and drivelines looking to put in a 8.8 whcih i will be sure to document well for everyone.
tkgibbs27 Posted January 14, 2008 Posted January 14, 2008 ok, could not be helped. everyone has green i know but it just looks so good! I had to do it... good looking truck. ha same color i am going to paint mine when i get a different one. the color looks good, and just makes the truck look even sweeter, i think anyways.
bhorocks Posted January 14, 2008 Author Posted January 14, 2008 i want to roll bedliner in the bed. still red..
bhorocks Posted January 17, 2008 Author Posted January 17, 2008 picked the up for $80 yeesterday.. 36x13.5x15 gonna look sick.. need toreplace two of em as they have no tread left but two were at 75%
offroader461 Posted January 17, 2008 Posted January 17, 2008 Those tires would look NARLEY on the MJ....i might have one at my work thats been there forever...they want really nothing for it..i have to verify the size...can't remember if its a 36" or a 38"...if its a 36" ill grab it for ya..they only want like 30 bucks for it and it BRAND NEW never mounted... :D
bhorocks Posted January 17, 2008 Author Posted January 17, 2008 that, would rock. i really need two to finish this up.
bhorocks Posted January 17, 2008 Author Posted January 17, 2008 yeah i still gotta get that 8.8. I priced it at the JY he said for 250 i could get one with discs and 4.10 if he will include the limited slip then i'll get it. that should net 1" of lift with the larger axle tubes. then i'll do some trimming also.
bhorocks Posted January 26, 2008 Author Posted January 26, 2008 well, got a lot done recently! pulled my transmission and got the new one in comparing the two trans. 4x4 on the right after getting it installed and a night time late flex shot.. best i could find at my house. gonna try to do a shakedown run tomorrow sometime. also need to hit the JY for Some springs for Offfroad461.
bhorocks Posted January 31, 2008 Author Posted January 31, 2008 well, picked up some junkyard buckets today for $30 bucks. took out that old bench seat i had. after that the floor was a mess. but instead of cleaning it i had to get my drivers seat in at least. and here we go with one seat. no tears in em and it is amazing how much space opens up with buckets. i didn't think it would be that noticeable also got my posilok in. can't wait to put it in the truck tomorrow night. got it for $50 dollars! Sweet!
CWLONGSHOT Posted January 31, 2008 Posted January 31, 2008 Looking GREAT!!! I am really liking the Green/blk look!!! The posi-lok is the bomb!! Get ready for 2WD lo baby!!! Keep the up dates coming!!! CW
