fiatslug87 Posted August 7, 2017 Share Posted August 7, 2017 Does anyone have the torque specs for the u-joint strap bolts? Same for front and rear driveshafts? Thanks Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 7, 2017 Share Posted August 7, 2017 From the Spicer manual: Technical Information* Fits Bearing Cap 1.938in For 1710/1760/1810 Series* 2.806in C/L to C/L* Crosses to 6.5-70-89-3 OEM Strap and 6.5-70-316 OEM Bolts 1/2in-20 x 1.00in Long* Torque to 115-135 lb.ft Link to comment Share on other sites More sharing options...
fiatslug87 Posted August 7, 2017 Author Share Posted August 7, 2017 Thanks Don. I didn't expect it to be that high and i didn't think the bolts were that big. I'm at work and will check tonight. Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 7, 2017 Share Posted August 7, 2017 I didn't either. I junked the crappy strap setup a long time ago and installed a U-Bolt Yoke Conversion Kit when I had to change the D44 pinion seal the last time out. $$ well spent. :thumbsup: Link to comment Share on other sites More sharing options...
Minuit Posted August 7, 2017 Share Posted August 7, 2017 1990 FSM has 14 ft-lb for the strap to yoke bolts. Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 7, 2017 Share Posted August 7, 2017 That sounds more realistic. I just checked my 91 FSM - 14 ft.-lbs. too. Ignore my first reply - bum info. Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted August 7, 2017 Share Posted August 7, 2017 I may be reading this wrong , but I think the strap bolts are 19n•m (14ft lbs ) set to torque 16-22n•m (12-16ftlbs) service recheck torque Link to comment Share on other sites More sharing options...
fiatslug87 Posted August 7, 2017 Author Share Posted August 7, 2017 Thanks guys, that sounds more reasonable. I think the bolts are only 1/4 inch. Link to comment Share on other sites More sharing options...
