Hello to you all, Hope you're doing great
The power steering pump on a '92 6 cylinder/manual MJ is leaking badly, think It needs replacement, Mopar's OEM goes for $250 at least...
Question is can you recommend a decent replacement that won't cost me 300 bucks?
Do you know if a 1990 XJ power steering pump will fit the 92 Comanche or are they not compatible
Any advice is highly appreciated
Regards
I used a pump from a low-mileage 04 TJ from the junkyard. Paid $40, and it's been in there well over ten years now. Most all the Jeep Saginaw TC pumps from 91 and up Jeep models will bolt right in.
Thanks for the advice
I can get my hands on a 1990 XJ power steering pump as a replacement my only concern is if the 90's pump will fit the 90's MJ
Sorry, I meant the 90's pump on the 92's MJ
Excuse the typo
When did I say I went by the compatibility chart ? I went by the factory part number 53008448 . I know the 2.5 pumps had a remote reservoir , I've had them .
