MJ steering components upgrade
In the near future, I will be lifting the MJ's suspension and while I'm at it I want to refresh the steering system. Sometime ago I read a write up somewhere stating that V8 ZJ parts are the way to go to beef up the MJ steering components, anyone have any leads to these details?  :wavey:
ZJ upgrade is simple and easy and cheap. Crown Auto sells a kit that is the same diameter as the stock setup, but solid rod instead of tube. For more gumbo, there are several companies offering 1 ton kits for the $200-300 range.
