Hi texasjack
Other more experienced will answer this better, but I think "Yes" is the answer. You would be using an HO engine in a Renix chassis so...
http://cruiser54.com/?p=100
as usal cruiser is the man!
Gene
Yep, just imagine it like a long block swap. You'll probably want to just keep all of the Renix ignition system. Cruiser's writeup should have all you need.
