8.8 swap question
I am getting ready to do a 8.8 swap. I was going to purchase new perches, however I was wondering if I could still utilize the shock mount plate for my shocks or is there a benefit of using something else? I have seen many kits however they seem to be for XJs and not MJs. I am staying SUA. Thanks
You sure can! Just need to drill out the holes to size. Those plates are really thick and can take it. I'm currently in the middle of this exact swap and thought my shocks were going to be too long. Reused the plates and put the aftermarket shock tabs in the parts box for later.
I can't remember off the top of my head. I ordered the easy swap kit from ruff stuff and everything worked out great. I got the 3 hole to push my axle back a tad bit since it was starting to creep forward with the new MT springs and longer shackles. I tried to get some pics going for you to show but on a gov computer and they're stupid slow. Pretty sure it was the 3.25 inch since its slightly bigger tubes than the 8.25 and they're 3 inch
I used the RuffStuff simple swap kit when I did the 8.8 under my 86. The perches I used were identical to the ones SBpunk linked. Since I was staying close to stock height and SUA, I liked having the availability to set the axle back a little so I could reuse the stock drive shaft+companion flange with the 8.8's longer housing. The perches you linked will work just fine to get the axle under the truck.
For the perch measurement, just crawl under your truck and measure center of leaf to center of leaf with the old axle still installed. Make sure you get the pinion angle set correctly before buring on the perches.
I used the spring plate/shock mounts from the exploder donor vehicle. Works fine.
Lol I wasn't that talented with the cut off tool. Looked like a shark chewed on the old spring plates
