Ax-15 or nv3550
When looking for an AX-5 replacement trans for my diesel swap, the knock I "heard" on the 3550 was that it could/was loud. My advice, buy whichever​ one you find a good deal on. Remember, the factory was happy with both. Likely also made a $$$ decision.
I have driven a few AX15s, and I have a NV3550 in my CJ7.  Yes, the NV3550 does have some gear noise while just sitting with the engine running, trans in neutral, clutch released.  I'm not sure it would be heard in an MJ with carpet, but I can hear it in my CJ.
Both transmissions have an overdrive that offers a substantial reduction in cruising rpms, which allows you to run your axle gears a little lower if you want to and still be able to run on the highway.  By contrast, the six speed NSG379 doesn't have a very steep overdrive, but makes up for it with a lower first gear.
I run 35s with 4.56 .  It drives great, I can take off from a dead stop with no throttle and cruise all day at 75 mph.
I've driven two different NV3550s, and both of them could be a little twitchy getting into second.  If you try to speed shift, it will grind sometimes.  Having a split second pause while shifting 1-2 cures it, for me.
As stated above, I'd take either I could find/get a good deal on.
I prefer AX15s. They can still be bought brand new which is a big plus for me. When the 6 speed in my LJ took a dump, I swapped a brand new AX15 in it's place.
Sent from my LGLS992 using Tapatalk
