DirtyDeeds Posted April 7, 2017 Share Posted April 7, 2017 so I'm about to rebuild and re gear my rear end to match my D30 up front but I'm not sure what axle it is, i originally thought it was a C8.25, but i was looking for the tag that might have the gear ratio on it when i noticed DANA stamped on the cover above the year of manufacture. also the shape of the cover looks a little more like the D35. can i get a positive id so i can order the proper gears? Link to comment Share on other sites More sharing options...
Jeep Driver Posted April 7, 2017 Share Posted April 7, 2017 That's a D35 Link to comment Share on other sites More sharing options...
HOrnbrod Posted April 7, 2017 Share Posted April 7, 2017 It's your money, but don't waste it regearing a D35 mate. Look around for a good used D44, 8.25, Ford 8.8, etc. first. What ratio are you looking for? Link to comment Share on other sites More sharing options...
DirtyDeeds Posted April 7, 2017 Author Share Posted April 7, 2017 It's your money, but don't waste it regearing a D35 mate. Look around for a good used D44, 8.25, Ford 8.8, etc. first. What ratio are you looking for? I'm not sure, I'm rebuilding my d30 high pinion this weekend and I'm looking to match the rear to the front. my mj was originally 2wd 5spd and my donor d30 is from my old 95 cherokee sport with a auto trans so i know the ratios most likely don't match. my d30 dosnt have the tag with the gear ratio any more so i won't know till i can count teeth while I'm re doing it Link to comment Share on other sites More sharing options...
Eagle Posted April 8, 2017 Share Posted April 8, 2017 If the '95 XJ was a 4.0L the ratio is 3.55 (or 3.54). If it was a 2.5L the ratio is probably 4.10. Link to comment Share on other sites More sharing options...
DirtyDeeds Posted April 8, 2017 Author Share Posted April 8, 2017 If the '95 XJ was a 4.0L the ratio is 3.55 (or 3.54). If it was a 2.5L the ratio is probably 4.10. 96* my bad came with Aw4 and anp242 thats in my MJ now Link to comment Share on other sites More sharing options...
Jeep Driver Posted April 8, 2017 Share Posted April 8, 2017 If the '95 XJ was a 4.0L the ratio is 3.55 (or 3.54). If it was a 2.5L the ratio is probably 4.10. 96* my bad came with Aw4 and anp242 thats in my MJ now Since your '96 was a Sport, it had 3.55 gears. I will second the advice to look for a 97+ 8.25..........or other.......... You'll be dollars ahead and fewer headaches. Link to comment Share on other sites More sharing options...
DirtyDeeds Posted April 8, 2017 Author Share Posted April 8, 2017 If the '95 XJ was a 4.0L the ratio is 3.55 (or 3.54). If it was a 2.5L the ratio is probably 4.10. 96* my bad came with Aw4 and anp242 thats in my MJ now Since your '96 was a Sport, it had 3.55 gears. I will second the advice to look for a 97+ 8.25..........or other.......... You'll be dollars ahead and fewer headaches. i would but its not in the budget right now. i really want a 8.25 from a zj with disc breaks but i don't have the time or place to cut off all the mounts and weld perches paint ect. I'm just trying to get it off road as cheap as possible for the time being. i found this used set online http://www.ebay.com/itm/Super-Dana-35-ring-and-pinion-gears-46131-48181-39-11-3-55-ratio-gear-Tj-XJ-WJ-/401219911454?hash=item5d6a91ff1e:g:qygAAOSwKOJYHJP7&vxp=mtr it should hold me over for a little while, I'm moving into a house in a few months then ill get a good 8.25. should i wait to conform the ratio in my d30 before ordering anything or should the ratio be pretty set? my xj was stock besides having 31's on it so i doubt any one did any swapping Link to comment Share on other sites More sharing options...
DirtyDeeds Posted April 8, 2017 Author Share Posted April 8, 2017 from what I'm reading here the d35 in there should have 3.07 gears. ive read some of the carriers are different and some times you have to find matching ones. will the 3.55 ring mount to the 3.07 carrier? Link to comment Share on other sites More sharing options...
HOrnbrod Posted April 8, 2017 Share Posted April 8, 2017 from what I'm reading here the d35 in there should have 3.07 gears. ive read some of the carriers are different and some times you have to find matching ones. will the 3.55 ring mount to the 3.07 carrier? There can be anything in there after all the years and owners. Just pop the cover and take a peek. The gear oil needs changing anyhow. :yes: Link to comment Share on other sites More sharing options...
jpnjim Posted April 8, 2017 Share Posted April 8, 2017 from what I'm reading here the d35 in there should have 3.07 gears. ive read some of the carriers are different and some times you have to find matching ones. will the 3.55 ring mount to the 3.07 carrier? There can be anything in there after all the years and owners. Just pop the cover and take a peek. The gear oil needs changing anyhow. :yes: Don has the best answer, here's what it *should* have: Link to comment Share on other sites More sharing options...
dante2 Posted April 9, 2017 Share Posted April 9, 2017 How bad do you need the 4wd? How about just bolting in the axle without the front shaft until you can get a better axle? I plan on swapping in parts to make mine 4wd but I will have to do it as money permits. I have been running my YJ without the front shaft for awhile due to a bolt broke off in the yoke. Link to comment Share on other sites More sharing options...
DirtyDeeds Posted April 30, 2017 Author Share Posted April 30, 2017 How bad do you need the 4wd? How about just bolting in the axle without the front shaft until you can get a better axle? I plan on swapping in parts to make mine 4wd but I will have to do it as money permits. I have been running my YJ without the front shaft for awhile due to a bolt broke off in the yoke. well its my toy and all the places i go on the beach you need 4x4 to get to, i picked up a used set of 3.55 gears on ebay that will hold me over Link to comment Share on other sites More sharing options...
