No running lights
Just put in a brand new headlight switch...noticed that i dnt have running lights...but if i bearly pull out on the knob they come on and sounds like a relay clicks...also when i flip my driver side turn signal i can hear 2 relays clicking...if i do the pass side just hear the one relay...any info is appriciated..ive had a few xjs but this is my first mj...btw it has no bed and no tail lights as of right now..its going to be a rig..but i may mount up some tail lights so i can drive it on the road now and then
G107 is the ground at the tail lights, make sure it is grounded.
There is a link to the electrical diagrams here somewhere, maybe someone can post it, I have it saved as a doc but no link.
You'll find it on page 94 once the link is posted.
Where does the fuel pump ground if you're not running a bed...I'd say that the ground is the problem.  If the "shared" ground for the fuel pump and taillights is disconnected, then neither should work.  If you have trailer wiring too, there is a common wiring light failure area.  So, this truck runs?
