Regular fuses instead of fuse links?
i was wondering if i could cut the old fuse links in the MJ and put regular fuses in their place, if so, how many amps? the web says red/brown fue links = 30 amps, is that correct?
i have a feeling that those are also $#!&ting on me...
I'd be interested in doing the same thing, I searched on line a while back and found a guy that swapped that birds nest with a newer style ( XJ ) fuse box but didn't give info on what amp fuse he used for what circuit.
Hi everyone,
I think you have to be a little careful doing this...
I believe a fusible link is very "slow-blow" so a similar fuse (same amperage) will blow much more quickly.
In other words, a 40 amp fuse run at 50 amps will blow fairly quickly. A 40 amp fusible link will take quite a bit longer to burn up.
So be prepared to replace more fuses than fusible links!
Gene
