Headlights and Blinker Problems
Okay so when I try to pull the switch for the headlights the first click which I'm pretty sure is supposed to be low beams, only the dash lights come on along with the tail lights. And then the next click the high beams come on. And when I try to use the turn signals or flashers they stay lit. On the dash they stay solid and the rear lights stay solid. So my problem is the turn signals staying solid with the headlights on and my low beam isn't working. Any ideas?
First click on the switch is parking lights. Headlights should not be on.
Dimmer switch is on the left side of the column. Pull it towards the wheel to switch between high and low beam.
Turn signals could be bad ground, bad flasher, or bad switch. My money is on the ground.
Hi crusher,
So when you pull the headlight switch all the way out, the headlights will come on. What happens when you pull the turn signal switch lever toward you? Do the low beams come on? Do the high beams stay on? Or do the headlights go out?
Gene
